82 vette pasenger vanity mirror - NCRS Discussion Boards
  • Don S.
    • February 1, 2000
    • 476
    The light in the passenger vanity mirror does not work. Fuse ok. unable to determine how to take apart the visor even with help of the AIM.
    Does this mirror part separate from the visor part with a snap and can be pried apart with a screwdriver. Can see no screws etc. to take it apart.
    Thanks in advance.
  • Michael D.
    • February 1, 1978
    • 159
    Re: 82 vette pasenger vanity mirror
    Don
    The screws are USUALLY under the light lens on MOST visors. You have to GENTLY pry the lens out from the longer end with a small screwdriver or pick then you should be able to see the screws. (two on each side)?
    Mike D #1787
    • Don S.
      • February 1, 2000
      • 476
      Mike--Thanks for the response , I was able to remove the two lenses with a small screwdriver but there are no screws or anything that helps.I also tried prying the mirror up using a small screwdriver--It won't come up and I am afraid I am going to bread something. Any other ideas??
      • Donald Brunswick
        Gently pry the mirror away from the frame. It is held in by two pegs on the mirror and two hard plastic recepicles on the sun visor. This is a very commom probem with these mirrors the switch is probably bad and unfortunately you can't replace it.
        • Donald M.
          • December 1, 1984
          • 498
          Don, the switch comes free with a new mirror!
          • Donald Brunswick
            Too bad the mirror cost $100.00
            • Chuck L.
              • July 31, 1996
              • 260
              Don, I had a similar problem with my 82 for 2 years and after repeatedly tapping the plastic post that activates the light, mine started to work. You've probably already done that, but just thought I'd mention it. See you in Florida! Chuck
              Chuck Lyman
              Kansas City Chapter
