C3-1978 Armrest reattachment - NCRS Discussion Boards
  • Barry #41479
    Any recommendations on the best way to reattach an armrest on a 1978. Both sides have pulled loose but I was able to fix the drivers side, at least temporarily, with the metal sleeve that is sold by most of the supply houses. I tried the same thing on the passenger side but the plastic insert that was originally at the end of the armrest has split and it will not hold.
    Should I try to glue the plastic guide back together and use the aftermarket metal sleeve or is there a better and more permanent way to fix it?
  • Mike Cobine
    Re: C3-1978 Armrest reattachment
    Don't know, but I have two in a '79 that are broken, too. I am thinking of filling the hole with resin and then redrilling a new hole. If it works, I'll let you know.
