C-1 61-62 Bellhousing - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Picked up two 593 bellhousings and on the top bolt hole that bolts to the block one has the hole for the bolt and the other one has the hole on the inside but has not been drilled out to the outside. Anyone know why it's not drilled? Thanks in advance.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C-1 61-62 Bellhousing
    i'd guess the drilled bell was probably a production bell while the non-drilled bell is service replacement. just a guess tho. mike
