If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Need a little help again. I finally broke down and purchased a new wiring harness from Lectric Limited. Of course the offer no instructions. My question is? Is there an easy way to run the wires through the door frame without taking off the door?
Taking off the door sounds like a lot of hard work plus getting them aligned again.
Jay, Don't take the doors off. I rewired my power windows motors with a new harness and never took the doors off. I did have a lot of the intreior apart, as I was doing a total redo of the interior at the time. You will have to take the wire loam tubes off and thread the wire through them. Don't for get to do that, other wise you will have to redo it. The hard part will be threading them through the dask. Check out the AIM manual. The center council will have to be removed as that is where the relay is, and of course, thre the firewall to the breaker and the hot connection - mine is the horn relay - not sure where on a 68. Good luck
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
