1970, 454, 4-spd.
I have been dealing with a vibration problem for over 5 years now. I have tried everything I can think of to remedy it...including waiting for the bad part to fall off. The vibration starts about 2800 rpm in 4th gear. I can't tell if it's there in other gears so I do not know if it's and rpm issue or mph issue. The vibration will rattle the shifter to the point it will shake your whole arm if you hold the shifter handle. You can feel it in the car itself, and also feel it in the gas and clutch peddle. The strange thing is, it's not always there. very rarely it will be gone completely. The norm is there. Once I get to 2800 rpm it is there. The strange part is the severity varies greatly. Sometimes it's there but tolerable, sometimes it is almost undrivable. The stranger part is that by pushing the clutch peddle in and releasing it a few times I can change the severity of it. If it's in the middle of being bad, popping the clutch peddle will make it much worse or much better. I have to keep doing it until it goes away...which is never completely, but about 90% better. I have run the car without drive belts, changed the engine and trans mounts, changed the clutch assembly, changed the entire transmission, changed carbs, played with timing and tuning, changed u-joints, changed wheels and tires. I do not believe it is in the engine because I can change the severity of the vibration which should eliminate a bad balancer ( checks good ) or unbalanced engine. I assume it's not trans related because the entire trans was replaced and flywheel resurfaced. My guess is that since popping the clutch changes it, I must be doing something to load or unload something in the chassis. I would think after all these years whatever is causing this would have broke by now. I'm at my wits end here and am thinking about watching a low milage original car vibrate down the side of a hill. lol. Please help !!
