67 Build Date (2) - NCRS Discussion Boards
67 Build Date (2)
  • 72-LT1
    67 Build Date (2)
    I have a 67 BB Coupe that I want to know a build date for. Can anyone help me determine when this car was built? It is car 114092. Thanks in advance for your help.
    Jeff
  • Mike Cobine
    Re: 67 Build Date (2)
    Check the date code on the trim plate under the glove box. It will be in the upper left hand corner. Something like:
    D3
    Style 437 A5091 Body
    Trim STD 977 Paint
    Get those and that will get you close.
    • 72-LT1
      Mike,
      Thanks I guess I should have listed those as well. My problem is that I have no source for the dates. I have just recently gottten into the 67's (been working on my 72 LT-1 for about 3 years).
      Here are my codes:
      Style H17
      Trim 67 437
      450 CA
      Body S4391
      Paint 976AA
      • Richard S.
        • November 1, 1994
        • 809
        From your VIN. number it would seem your car was assembled on or around Monday, March 20th, 1967....just 14 days before mine.....enjoy.
        • Jeffrey S.
          • August 31, 2000
          • 33
          Rick,
          I appreciate it. The reason I am asking is that all the numbers I can find confirm that date but the protco-plate is dated 1-26-67. That would be impossible. A few guys here have seen that before and say that sometimes the Dealership used the order date. The dealership probably just made a mistake since everything else matches and if someone was going to fake a car (and do it well)they would not leave an incorrect protecto-plate to give it away. Anyway thanks for your input.
          Jeff
            Trim tag numbers and VIN line up nicely - body built Friday the 17th, came off the line on Monday the 20th. When you say P-O-P date of 1/27, are you talking about the date on the Dymo tape, or the written delivery date on the warranty folder? The P-O-P was made and applied to the folder at St. Louis.
            • Jeffrey S.
              • August 31, 2000
              • 33
              Yes I am talking about the written delivery date and the Dymo tape on the P-O-P.
              Jeff
