67 soft top mounting bolt finish - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    What is the correct finish for the four bolts that fasten the soft top frame to the body? I assume that there should be no overspray on them. Is this correct?
    Re: 67 soft top mounting bolt finish
    Dunno, but I'd like a description of P/N 3829442 also; that's the only place it's used in the whole car, and mine aren't correct. No overspray on them.
    • Randy R.
      • March 1, 1983
      • 477
      The bolts I have appear to be either a black oxide or a gray phosphate. (Too worn to tell the difference.) Based on the black being a more common treatment for other fasteners, I will refinish them in a black oxide if I have to guess.
      • Michael H.
        • January 29, 2008
        • 7477
        Randy/John,
        If no one else happens to have one of these bolts out of the car and available for viewing, let me know and I'll remove one of mine. Just by looking down at it, I would call the plating grey, not black, but difficult to tell for sure without close inspection.
        Michael
          Michael -
          Is it all one piece with a flanged washer head, or does it have a captured free-spinning conical washer? The A.I.M. calls it out as a "screw", not a "screw asm.", which normally is the differentiator.
          • Michael H.
            • January 29, 2008
            • 7477
            John,
            Looks like captured loose washer. Appears to be a conical washer but it's difficult to tell without removing it. It has a counter sunk head. I'll try to get one ont in the next hour or so.
            Michael
            • Michael H.
              • January 29, 2008
              • 7477
              Looks like "ELH" and the washer is loose but attached and conical.
              • Randy R.
                • March 1, 1983
                • 477
                I will check the head markings on mine and reply tomorrow.
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  A point of interest. On Hard Top only cars there is one bolt installed in each side and it may have body color overspray.
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Wayne,
                    Funny that you should mention that. My 66 is/was hardtop only but soft top was added a few years ago. There was only one correct bolt in each side to hold the tapping plate in place. There is now one correct and one Dorman bolt on each side. I see no traces of body color or primer on the bolts or mounting tho.... I'll have a closer look.
                    Michael
                    • Wayne W.
                      • April 30, 1982
                      • 3605
                      They installed one on each side to keep the retainer bracked from rattling. I thought that the bolt should have been there when the body was painted, but I might be wrong on that account. I have a yellow example that shows some overspray. I dont think the car had be repainted, but it may have.
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Wayne,
                        I believe that the single bolt would have been installed at the same work station as the soft top assemblies. It would make sense as materials/bolts and tools for that operation were there.
                        I inspected both bolt holes on one side of the car and I see maroon paint in both areas.
                        • Wayne W.
                          • April 30, 1982
                          • 3605
                          That make sense. You are probably correct.
                          • Mike M.
                            Director Region V
                            • August 31, 1994
                            • 1464
                            Black Phos, Bolt and Captive Washer *NM*
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Re: Black Phos, Bolt and Captive Washer
                              Michael,
                              Is black phos a grey plating or does it come out black? My original bolts are definitely not black, especially behing the washer, an area that was protected from the elements. More like a medium grey. I suppose that the source, or sources, could have used either plating, resulting in a mix of both colors on the cars.
