67 soft top weatherstrip mounting screw - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    What type of fastener is used to attach the rear bow weatherstrip block? This is the small piece of weatherstrip that fastens to the ends of the rear bow. I received a convertible top fastener kit from LI Corvette. In it are four #6-32 flat head machine screws. The holes in the aluminum frame look like they could match these machine screws, but I question the use of a flat head machine screw. Are these supposed to be flat head or should they be pan head screws?
    Of course, I did not remove any #6-32 fasteners from the top when I disassembled the frame but it had been redone once before.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 67 soft top weatherstrip mounting screw
    They are pan heads.
