65 brake line clips (to frame) - NCRS Discussion Boards
  • David H.
    • December 1, 1996
    • 241
    what is the method of removal on these clips?, if you want to save them. and/or which vendor sells the proper clips? Thank you in advance; David
    Re: 65 brake line clips (to frame)
    David -
    If you mean the green clips with the hollow tubular rivet in the middle, it's tough to remove them without damaging them; they were originally installed in the hole in the frame when the rivet was straight (not expanded), then a "burp gun" with a pointed/tapered shank was used to expand the rivet inside the frame to retain them. Paragon has replacements - about eight bucks each.
