This is a two part subject. First, has anyone any input on wiring harnesses from Lectric Limited, Eagle Wire Products, or M&H Electric Fabricators. Input such as quality, availability, but most important, original appearance . Now on to the second issue, I've read many posts concerning a replacement ignition triggering system to replace the stock points setup. If you want a simple (1) wire conversion that looks totally OEM, operates by (hall-effect) has protection circuit which shuts system off if ignition is left on, and can also be installed without removing the distributor. Check it out at www.breakerless.com , let me know if you have tried it, or just what you think about it. They have a very informative sight.
Thanks, Lawrence Berte
