69 muncie trans - NCRS Discussion Boards
69 muncie trans
  • kelly theaker
    69 muncie trans
    pulled the trans out over the week-end because of speedo not working , found the gear sitting on shaft just forward of the hole , gave a bit of leverage with a screwdriver and it moved. i can move this gear back and forth on the shaft with a bit of pressure, i cannot see a clip on the gear . Question -should i be able to see the clip? should i be able to move the gear? and the correct placement of the gear- in front of hole in trans , slightly off to one side ? and the input shaft was picking up a bit of the pilot bushing , should i install a new bushing or install a bearing? and when installing the bushing do you immerse in oil overnightand a bit of grease on install of trans or is this bushing pre lubed for life.
  • William C.
    • May 31, 1975
    • 6037
    Re: 69 muncie trans
    The gear inside the trans should not move, and you will likely have to pull the tailhousing off to find the problem. If it is a plastic gear, the clip will locate it in the correct position, it only goes one way, and the clip locates via a tang that goes into a hole in the shaft.
    Bill Clupper #618
    • kelly theaker
      Re: 69 muncie trans
      just followed up with Bill Clupper and called J.T Pipers 1800637-6111 and spoke to darrell . they also reinforced me with old stock on hand and the knowledge. great place and people .
