R89S Battery Question for 1971 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    Judging manual indicates the battery caps are 2 caps containing caps for 3 cells each.
    All references I can find indicate the R89S had 5 caps and 1 cap with an eye.
    Is there any souce for the correct information.
    I would like to purchase a correct battery as the one I have has died, so I am asking for a resource also.
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
    • 15573
    Re: R89S Battery Question for 1971
    Ralph,
    R89S, as well as R 89W and R79S & W, batteries were delivered to the PUBLIC with five caps and one cap with an eye -- as your references indicate. Those batteries INSTALLED on Corvettes were delivered to St. Louis, where the two caps as described in the judging manual were installed. We do not know what kind of caps they had for shipment to St. Louis, and since we judge the car as assembled and delivered, it doesn't matter what caps they had for shipment.
    To the best of my knowledge the R89S battery is not reproduced, so your only chance of finding one is someone who has an old stock dry battery just waiting for you. The R89W is being reproduced, and works well for judging, since we do not ask for build documentation regarding the original type of battery installed. The R89W was installed as the heavy duty T60 battery option.
    The two caps as described in the judging manual are also in reproduction, or were several years ago. My examination of the reproduction caps revealed no discernable differences from original.
    • Dave S.
      • August 31, 1992
      • 2918
      Ralph,
      Your 71 should have the 2 vent hoses which connect to the battery caps and run through the bottom of the battery tub. The 2 caps w/ 3 cells each and the vent outlet is the correct installation as per the JG. Both the R89W and R89S should use the same battery caps however I believe only the R89W is reproduced.
      • Ralph A.
        • May 31, 2002
        • 236
        Manual said both batteries had the same caps. Will the R89W caps work for the R89S?
        RA
        Ralph Adams
        NCRS: 38137 LA: 112
        Slidell, LA 70461
        • Ralph A.
          • May 31, 2002
          • 236
          Can I put the R89W in the car. I do not know if the car came with the T60 option or not. Do not have original build sheet.
          Let me know
          Ralph
          Ralph Adams
          NCRS: 38137 LA: 112
          Slidell, LA 70461
          • Ralph A.
            • May 31, 2002
            • 236
            Thanks to all, I purchased a R89W
            I hav A/C and may have the T60 option, so I ordered the real replacement.
            Thanks for the responses.
            RA
            Ralph Adams
            NCRS: 38137 LA: 112
            Slidell, LA 70461
              • 15573
              As Dave says -- same caps for either battery.
              Yes either R89S (if you can find one) or R89W will fit in the space allocated for the battery on your 1971. The physical size of each of them is not that much different.
              • Gerard Q.
                • February 1, 2000
                • 284
                You know what they say about a picture.....
                • Ralph A.
                  • May 31, 2002
                  • 236
                  Could not open picture. please email *NM*
                  Ralph Adams
                  NCRS: 38137 LA: 112
                  Slidell, LA 70461
                  • Gerard Q.
                    • February 1, 2000
                    • 284
                    Check it now Ralph *NM*
                    • Ralph A.
                      • May 31, 2002
                      • 236
                      Thanks, will save the picture, *NM*
                      Ralph Adams
                      NCRS: 38137 LA: 112
                      Slidell, LA 70461
