I am having the worst time installing this set of side exhaust from Stainless Works on my '67. The passenger side fits perfect, the pipe is equal distance along the length of the frame and clears the frame when it runs underneath it from the engine by about 3/4". Now the drivers side is a different story. In order to clear the frame as it runs below, I need to position the pipe down in the front so that it contacts the frame on the side just after it makes its 90 degree bend to the rear. I am only able to get about 1/8" clearance under the frame that way. If I position the pipe so that it has equal distance along the length of the frame it has full contact with the frame as the pipe runs beneath it. Either way it hits. The manufacturer said these are all CNC bent per the original pipes etc. They are willing to make a new section of head pipe for me. I just wanted a sanity check from the board before I do that.
Thanks for the input.
