'73 Coupe.....Originality Obsession Worth It? - NCRS Discussion Boards
  • Lonnie Wiggins
    In 1987 my brother, due to reasons unimportant here, parked his '73 BB, with 33,700 miles, in a garage with a solid door...no UV exposure at all. Until last week, after having the motor pulled and gone through, the car hadn't been started/run/driven, going on 18 years.
    We're in the process of getting it back on the road.
    Except for one "minor" exception, the car is completely original. The interior finishes and surfaces have no fading, cracking, or deterioration - the leather seats et al appear at this time to be as they were when parked. All instruments, including the clock :-), work.
    While redoing the motor, the accessories were rebuilt, not replaced...the A/C compressor was rebuilt, for example, but not refinished and still has the orignal sticker. In the process, the front end was rebuilt with new bushings....my one problem with the job was that the a-arms were cleaned and painted contrary to my instructions.
    The paint is in very good shape and polishes out with no problem. The car still has the original ralley wheels.
    In a nutshell, the car could be a really good original car.
    Except for the one "exception". In 1977 my brother "tossed" the original BB and had installed a LS6 short block (less solid lifter cam) along with the open chamber service heads ('77 date code) and an L88 intake under an L88 style hood. The car was't otherwise altered.
    So, finally, my question is....is worrying about "originality" at this point - other than the motor - worth it other than for our own satisfaction? As near as I can tell for judging purposes, the engine swap pretty much knocks it out of any contention. My inclination is, regardless, to maintain the originality in the rest of the car...but am I being too anal about the whole thing? I'd welcome comments from others and apologize for the length of this disertation.
  • Mike Cobine
    Re: '73 Coupe.....Originality Obsession Worth It?
    In 1977, your brother did a good move, considering that was still a time where the right foot ruled and the '73 454 was ok, but not great.
    In 2004, you'd like to kill him, but all is not lost. You simply need to have a block with the right casting numbers and dates. You probalby can not hit the right assembly numbers on the stamp pad, and you won't get the right VIN, but you are in an area where you have some points even while losing others, if your goal is judging.
    If your goal is selling, then regardless of how original the car is, most will ask one question - "original engine?" - and drop you when you say no like you are plagued or something.
    And much of your approach should depend on who owns the car and what they want.
