If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I need to raise my 67 Coupe drivers door up at the front, to fit better with the top of the front fender. I see the hinge mounts in the door will allow movement front to rear, but no up and down.. Can the bolts that hold the hinge to the cage be loosened to move the door up??? Thanks, Kurt
The hinge-to-door attachments provide all three adjustments (fore-aft, up-down, and in-out); there are no adjustments at the hinge-to-body pillar attachment.
Thanks guys for the info. I took one bolt out and saw the hinge was slotted to allow front to back movement only. I will put a jack under the door and try to lift it.. I heard these doors are a bit tough to adjust. Kurt
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
