Rear filler plate rivets for 63 SWC - NCRS Discussion Boards
  • Rainer S.
    • May 31, 2003
    • 468
    What is the size of the rivets, which attach the the metal plates to the rear bidy panel.(the plates provide the screw holes for panel filler plate). Are the rivets "flathead or countersunk/flathead".The number of the rivet is 3828810, per assy manual.
    Also, who sells these rivets ?
    Rainer
  • Rob A.
    • December 1, 1991
    • 2126
    Re: Rear filler plate rivets for 63 SWC
    long Island sells the rivets and the nut plates for the rear exhaust panel, they're flat head and fit flush by way of the recessed area in the fiberglass. If you heat them up some to soften them, the're easier to install.
    • Rainer S.
      • May 31, 2003
      • 468
      Thanks, Rob. Found the item in catalog...
      Rainer
