I;AM THE OWNER OF A 1963 327/340 SHP. ROADSTER #12921 LATE "63" QUESTION IS WHICH TRANS. IS CORRECT ? IS THERE TWO TRANS WITH THE CORRECT ( # 278 ) SMALL RETAINER ? FOR THE 421 BELLHOUSING . I HAVE SEEN TWO TRANS . FOR SALE ONE IS A 220 CLOSE RATIO & THE OTHER IS 256 WIDE RATIO .... WHICH IS CORRECT FOR MY CAR.COULD YOU ORDER EITHER TRANS BACK THEN . JUST WANT THE CORRECT ONE . CAR WAS BUILT 4/15/63 . THANKS NCRS MEMBER .
1963 trans. ( wide ratio vs. close ratio )
Re: 1963 trans. ( wide ratio vs. close ratio )
Pat,
If your car is an original 340 HP, it would have had the 2.20 close ratio 4-speed. All 340 and 360 HP cars came that way in 63. It would have been called M20 instead of M21 on any paperwork that you may have for the car but that was just to indicate "4-speed" and not ratio. The ratio was determined by the engine option.
All 63 4-speed cars, regardless of early/late Borg Warner/Muncie, had the small diameter front bearing retainer and 421 clutch housing.
Michael- Top
(1) Turn off your caps lock! According to 'netiquete' the use of capitals is intended for emphasis. You're inadvertently YELLING at us in your posts which I don't think you intend to do....
(2) The issue of wide vs. close ratio regardless of transmission mfgr (Borg vs. Muncie) has to do with engine horsepower rating and nothing else.
(3) The change from Borg to Muncie is well documented in your copy of the 1963-64 NCRS Technical Information Manual & Judging Guide (available at the 'STORE' on this website). In the Chassis Section, Item 10, Transmission, you'll read:
"....An optional 4-speed transmission is available which is manufactured by Borg-Warner for most of 1963 production up to approximately VIN 1500, and by Muncie for the remainder of 1963 and all 1964 production...."- Top
I believe that is up to 15000 vin, at least per my JG and the vin on various '63 T-10's I've seenBill Clupper #618- Top
