I figured I would ask the experts which parts of my clutch setup might be contributing to my on-going adjustment problem. I am at the extreme end of the adjustment of the clutch linkage. If I adjust the linkage as the service manual suggests, the clutch will just barely disengage at the floor. I would like to confirm that I have the right parts installed. I went back to my GM parts purchase receipt from 1986 when I last had the clutch apart and found the following:
Fork - 3887177
Stud - 3887159
Bearing - 908244
Plate - 458629
I have confirmed that I have the correct lower link rod in place (8+ inches), and best I can tell I have the original and correct crossarm. Rod connected directly to the clutch pedal is original and in good shape.
On a side note, the AIM refers to 1.5 inches of free play at the pedal. Wow that seems like allot! To get my clutch to work even close to correctly I end up with at most 1/2" free play. I wonder where the disengagement point is SUPPOSED to be after following GMs adjustment procedure?
Suggestions?
Fork - 3887177
Stud - 3887159
Bearing - 908244
Plate - 458629
Suggestions?
