Need info on a Doug Hubert solid lift cam, 500 lift, and hypereutectic pistons.I was told they are between a Forged and Cast type piston.
Looking to rebuild a '70LT1 engine with better driveability and to run efficiently with todays pump gas 93-94 octane.I will reduce compression to 9:0:1 with moly rings,new rod,main,cam bearings,new high volume pump,HD drive and oil pickup.A new LT1 crank, magged and polished.The block will be bored .30 over using the correct 186 heads 2.02 x 1.60 valves stainless steel or hardened exhaust seats,new solid lifters,valve springs,keepers,retainers rockers,screw in studs and guide plates.
I expect HP to be close to stock 370 with better torque.Engine would be balanced and all other LT1 engine parts will remain the same,TI Ignition System,Holley 780,Aluminum Intake,etc.
Any other help on this rebuild would be appreciated.
Greg
Greg
