72 rocker trim captive nuts - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    I noticed that my 72 is missing a couple of the captive nuts that hold the side rocker trim on. Can you gets these captive nuts anywhere? How tough are they to install?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 72 rocker trim captive nuts
    Ed What I bought from a vendor was a 5/16 X 1/2" long bolt that was drilled and taped to the thread size of the original screw. You then drilled out the hole to 5/16 and installed the special bolt with a nut. If you have a drill press you can make them if you have the time. I have just drilled out and retaped the original hole if the screw was broken off. Lyle
    Lyle
