C1 Soft top frame - NCRS Discussion Boards
C1 Soft top frame
  • Kevin Riel
    C1 Soft top frame
    I'm in the process of going completely through the soft top on my '59. Does anyone know what is used to hold the tack strips in? Is it contact cement? Also, were the tack strips put in place before or after painting at the factory? Thanks in advance!
    Kevin Riel
  • Allen W.
    • September 30, 2000
    • 106
    Re: C1 Soft top frame
    My experience is only on reproduction top frames. The tack strips are epoxied in or glued in some how. Reproduction tack strips are avaliable if you need them. They are very hard plastic/rubber and hold staples well. Staples are what most people use even Al Knoch. I can give addition info if desired.
    Allen
    • Kevin Riel
      I've got a total soft top recover kit from Al Knoch, so I also have new tack strips. They appear to be a type of cardboard. They are light in color.
      Kevin Riel
      • Lee Boyer
        I have just replaced my top on my 61 and the strips are a very tight fit. When i removed them i didn"t notice any glue I beleave they are a press fit. You may have to shave the replacements down a little and work them in. this may take a wile. If you look at the replacements you will notice that they have a beveled edge. Good luck.
