1966 emergency brake handle removal - NCRS Discussion Boards
  • Jerry N.
    • March 1, 1999
    • 32
    I want to take the emergency brake handle and assembly out of the car but can't figure out how the cable gets disconnected to the end of the emergency brake rod under the dash. Any help would be appreciated. Thanks Jerry Nutt
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1966 emergency brake handle removal
    cable has barrel end on it ionside the cockpit. you have to grasp cable and push it into the cockpit(up into the hollow portion of the handle then , with ebrake assembly unbolted from firewall, turn the assemble to allow the barrel end of cble to be freed up from hollow shaft that has a slot cut in it. all this has to be done after the front emergency brake cable assembly is freed up from the rear calbes and the return spring.( hence no resistance to your pushing the cble into cockpit.)mike
