1116368 Benchcheck - NCRS Discussion Boards
1116368 Benchcheck
  • Loren L.
    • April 30, 1976
    • 4104
    1116368 Benchcheck
    I've acquired another of these TI regulators, just to make sure that when (and if) I get the car together, I'll have one. Is there a method of benchchecking that I can use now to validate the units or ????
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1116368 Benchcheck ('65 Transistor volt reg)
    Loren -- The 1965 New Product training program booklet (TP-34) has this to say:
    When servicing the full transistor regulator system, proceed as follows:
    1. Check the continuity of the entire circuit in the SAME MANNER as the double-contact, two-unit regulator.
    2. The regulator parts are not serviced separately. When a regulator is determined to be faulty (either the field relay or the transistor section), the entire regulator must be replaced.
    Delco Remy Test Spec's DR-324S-2 shows Test Spec's (Bulletin IR-187) for 1116368 to be found in serivce bulletin IR-266, spec No. 4237 [which I don't have]. Voltage chart # 7 gives field relay closing voltage range and cutout relay voltage range and voltage setting range for 7 temperature points between 65 and 185 deg F, whereas the specs at the end of ST-60 give values only for 85 deg F.
    Your Corvette Shop Manual '65 Supplement ST-60, section 6Y describes tests to determine the faulty unit (Delcotron or volt reg) -- if it's 1116368, you have a really neat paperweight.
    4L, eh ?, (Wayne 4K)
    • Dick W.
      • 10483
      Loren, somewhere I have a Sun regulator tester with the leads to test them. I can hunt it up if you want me to check it
      Dick Whittington
      • Loren L.
        • April 30, 1976
        • 4104
        Yep, 4L, TWO 5C's and a REAL paperweight, a 378 7K. Begins to sound like I'll just take them over to Ward Gappa's, disconnect his and plug mine in and watch the ammeter.
        • Dick W.
          • 10483
          They are repairable. In my great piles of useless and worthless manuals, I gave the manual that spells out the procedures
          Dick Whittington
