What is the proper orientation for the "spring" in glove box hinge assembly (1964)? It seems obvious that the end of the spring forming a circle is bolted to a specific hole on the right hand side of the glove box door, but the orientation of the other side of the spring is not as obvious.
Both ways I tried ended up with either:
a)the glove box door being pushed down too far by the force of the spring such that the latch would not engage properly (latch catch 1/4 inch too "high" to engage latch), or
b)two hands are required to open the glove box because there is not enough pressure/gravity to push the glove box door away from the latch catch while pushing on the latch release button.
Is there another spring somewhere that I am missing? Probably a silly question, but I am at an impasse on this right now.
Thanks!
Thanks!
