C1 wiper motor removal... - NCRS Discussion Boards
  • Pat #25912
    From my sercice manual it appears that once the power lead and control cable is disconnected, and the 3 screws removed the motor just lifts off. Is that all there is? I don't need to mess with pulleys and cables? Thanks again.
  • Ed Jennings
    Re: C1 wiper motor removal...
    That is correct. The motor connects to the pulleys with a rectangular plate that fits inside a channel on the pulley. There is a felt or cork spacer that goes in between, so don't lose it when you pull the motor off.
    Be sure the wipers are in the park position and don't disturb them with the motor off. When the motor is serviced, return it to the park position as well, and everything should fit right up.
    • Robert C.
      • November 1, 1993
      • 34
      That's right. The motor is mounted to a plate which attaches to the cables.
