rebound strap installation/spring compression - NCRS Discussion Boards
  • Dave Christensen
    I have a '56 with a nearly bare frame. I have installed the rear springs and differential. I am trying to install the rebound straps but I do not have a good method of raising the axel up enough to get it inside the rebound strap to install the rivets.
    A floor jack lifts both the axel and frame since the frame is almost bare. What's the trick?
    thanks Dave Christensen
