Well I am building a 1962 corvette (not excactly "factory correct") any ways the car was paint stripped by chemicals prior to me purchasing the car.I had what every paint that was left on the body media blasted off.
So now the car is ready for a couple of repairs,Stress cracks.And re attaching a replacemennt front left corner of the car,and also a pretty nasty cracked damaged area above the drivers front tire.
So my real question here is what should we use to seal the car? I have done a search of the archive and have not found the information I am looking for.
The reason I feel we need to seal the car is there are way too many areas where the the glass is hairy,wavy,thin,slightly damaged,body seams needing attention.So it would seem like the entire body would have to have almost an entire plastic skim coat on it.Is this what sealer fixes?
I have heard the terms
"slick sand"
"high fill primer"
"gel coat"
"DP"
The car is in a body shop for the repairs and a repaint and I want them to use what is best for the car.
The finish paint is going to be a 2 stage urathane made by ppg called global.
Thank you in advance for your help
Larry
"slick sand"
"high fill primer"
"gel coat"
"DP"
Larry
