In the 67 Assembly Manual in the section addressing "4 Speed Rod Adjustments" it refers to a "Locating Gage (Gauge ?)". Where would someone purchase one of these or is it easily fabricated from flat stock? Thanks to all responces. Bill #20328
Tool Availability ?
Re: Tool Availability ?
I was going to make a fancy one out of steel until I realized a paint stirrer was the right thickness and much easy to trim. That is a serious comment. I had the steel out and moved the paint stirrers out of the way to make work room when the light bulb lit.
Dave
- Top
In addition, I think most of the service manuals have one pictured as well as instructions on how to make it including dimensions.
I made one, but they are a MAJOR PITA to use with the body on the frame. I do as well adjusting linkage without using the special tool.
PatrickVice-Chairman (West), Michigan Chapter NCRS
