Re: '69 Monaco Orange Coupe - NCRS Discussion Boards
  • Kieran A.
    • April 30, 1987
    • 87
    Rod , I had a 1967 Coupe with an early November build date that also had the paper vapor barrier setup. The difference between earlier years is that the door lock hole cutout was repositioned for the 1967 year(more forward).If you decide to replace the paper type, you will have to cut a new hole for the lock. I kept the passenger door barrier and you are welcome to it if you need it bit it has a lot of maroon overspray on it from a repaint. Regards, Kieran
