Another Winter project are the door panels on my '62. I have the usual problem that the mounting screw holes are enlarged to the point where even an oversize screw won't hold. Time to rebuild the holes. I know about reglassing the holes, which I don't want to do. I know about using those plastic inserts used to hold screws in drywall or masonry. May do that in some places.
Also know that Corvete Central sells a kit for this purpose. The kit consists of metal squares and pop rivets. You install the square over the hole with pop rivets. Then drill a new hole into the metal square.
Anybody have any comments on this technique?
Any other ideas on ways to fix this problem?
