Cleaning Frame - NCRS Discussion Boards
Cleaning Frame
  • Edward M.
    • November 1, 1985
    • 1916
    Cleaning Frame
    cleaning frame ed mccomas i am wondering what is the best method for cleaning a frame i have a frame that has lots of surface rust but solid metal sand blasting is one option but i am wondering about the value of having the frame acid dipped any thoughts on acid dipping pros and cons are there any reasons not to acid dip what about protecting the frame after it has been acid dipped from huntsvile al to cloest place that i know of that can acid dip a frame is readystrip in evansville indiana that is about a four hour drive if memory serves correctly what should be done to protect the frame after it is acid dipped any thoughts would be appreciated
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Cleaning Frame
    re cleaning frame gene manno ed i've done both acid dip and sand blast acid dip cleans the inside of the frame something blasting is limited in doing but coating the new bare metal inside is not easy most places in the frame if these are not coated rusting appears to speed up complete removal of all the acid was also a problem for the next several months even after painting it appears to weep out of the seams painting should be done asap due to acid's ultra cleaning effect on steel be sure to neutralize the acid prior to finishing now blasting will not remove rust inside closed frame members but you don't see it any way that old rust inside should not be any worse years from now yes i prefer blasting hope this helps you
    • John, 29200
      Re: Cleaning Frame, without removing
      re cleaning frame without removing john what have people used to clean a frame of surface rust i dont want to do a frame off yet years i will as the car is original the frame is solid i have seen lots of products that claim to help but they dont is this a matter of days underneath with a wire brush
      • Wayne
        Re: Cleaning Frame
        re cleaning frame wayne john i'd do both i did one using acid dip then had some trouble with the paint appearance perhaps i didn't neutralize it enough after getting it back from dipping or perhaps the paint store screwed up the paint formula whatever the problem i ended up grinding it back down to bare metal and repainting it my suggestion is to get it dipped then take it for a very light sandblasting on the outside to aid paint adherence coat the inside with antirust you can buy a kit about with the material spraygun and extension rods from eastwood or j c whitney i did the outside of mine with self etching imron primer and slightly dulled black imron
