C3 vac pods new/used wanted? - NCRS Discussion Boards
  • dick foehringer
    someone has to make them? the diaphrams are ok its the shaft seal/gromet thats bad. even if someone has the gromets, you couldnt put them on as the bracket is welded to the shaft. since both of mine are bad im assuming its a common problem....help!?!?
    thanks, dick
  • Michael W.
    • April 1, 1997
    • 4290
    Re: C3 vac pods new/used wanted?
    I guess you're talking about the headlight actuators, and specifically the outer seal and bellows. Replacement parts are available from all the usual vendors.
    The end pivot is not welded to the shaft (at least on the years I'm familiar with) it's threaded on, and secured with a jam nut.
