The passenger tranny in the '62 doesn't work. The local Corvette guy had a look and tried to wind the cables but could not. He pronounced that I have 2 left-hand transmissions on my car and I should find a right-hander. Called Tom Maxwell, arranged to get a right side unit. Well, I go to pull the passenger side unit from the car today, and the hole thru the body is keyholed towards the middle of the car, so maybe each sides' tranny would only fit that side. And on the side of the curved shielding over the cables is an R. And on the base of the wiper mounting plate it says 58R. On the driver's side wiper tranny it says 58L. I will assume that I'm an idiot and I really do have the correct set of left and right trannies, correct?
In any case, I cannot get the pullies to rotate with respect to one another, and I cannot push down on the shaft and free the pullies in any way, so I ASSume this unit needs to be rebuilt- off it goes to Gaithersburg.
