my 69 barn car has most of everything un touched, but i have a question on the correct place to connect the dist vac advance. it is an a/c, 4sp car and when i tore it apart the hose was connected to the side base plate of the center carb. it also had the clip on one of the valve cover bolts that i think held the steel line that was part of the vac hose connection. the steel line was missing. some other pictures show the vac line hooked directly to manifold vac. i have a 3 port vac connection in the manifold. a large tube for PB, a center port pointing up that had a cap on it , and a ribed port that was hooked to the vac canister. so which way does it go? it seems to me the 3 ports would be used for PB, A/c vac and vac tank?
thanks, dick
thanks, dick
