I cannot get my wiper motor to work on my 68. If anyone can help, here is where I stand and what I have tried. First, I have a remanufactured delco unit, I am not sure that the wires on the motor are the original color, and hence not sure where to hook them to. There are three wires on the 68 wiper motor that hook to the engine harness pigtail. My motor has two loose wires that come from the gearbox area, a red and a black. There is also one loose wire that comes from the motor, this wire is white(there are also a red and black wire coming from the motor, but they are attached to the resistor area by the gearbox). The connector in the engine harness (the above mentioned three wires from the wiper motor plug to this three wire connector) has a red wire, black wire and brown wire. What is the correct orientation for these wires? Since I am not sure of the correct color schematics, to which wire does the single wire coming from the motor area (my white wire) attach?
I have purchased a new switch and verified that it has a good ground, and grounds the proper terminals when I switch positions. The switch relay is in place, and it clicks when I move the switch.
I also verified that the wiper motor has a good ground coming from the heater motor. The fuse is good, the middle yellow wire on the three wire connector that plugs to the resistor area is hot. The red wire on the engine harness pigtail is also hot. I am not using a wiper washer pump, just a plastic cover to cover the gearbox, so the yellow and dk blue bullet connectors are not connected.
Also, I am not using the wiper door mechanism, so I jumped the limit switch.
I can send digital pictures or diagrams if needed. Please help! Thanks, Jeff
