I parked my car, running fine. A week later I went to start it and nothing. No interior lights, starter, exterior lights, radio, etc. The horn worked. I checked the battery and it was fine. In looking under the hood, I discovered that a wire coming from the horn relay into a large bundle of wires under the master cylinder had burned in two, and had shorted against the brake line coming from the master cylinder. There are two wires coming out of the bundle that have large hard rubber sleeves,each about 3/8's of an inch thick and 5/8's long, covering the connections. The wire that had burned in half was one of these. I repaired the parted wire and again had lights, radio etc. When I hit the starter, nothing. The second time I turned it, still nothing, but the interior lights went away. The third time I tried the starter, I noticed a tiny wisp of smoke come out of the voltage guage. This happened twice, a wisp of smoke coming from beneath the needle, under the glass.
Any suggestions of what is going wrong would be appreciated.
It's a 350 auto with ac, ps, and pb's. Original dist and wiring. Horn relay replaced about a year ago.
Thanks, Tom
Thanks, Tom
