Re: C2 - Side Exhaust Conversion
Roy, Don't let those guys get you down! Do what you want to your car. I have side exhaust on my '67 small block and it sounds just great. It's not too loud on long trips, either. Maybe because it's a small block, I don't know. You will also have the added benefits of lots of room to work under the car and a set of pipes that will virtually last the life of the car (or as long as you own it?) This is because they get hotter than an undercar system and thus burn off moisture which accumulates in the rear-mounted mufflers of an undercar set up and leads to premature rot.I know a guy whose side pipes actually rotted out--at 250,000 miles!! VROOM!
