My new gas tank vent tube connection solder is cracked. The connector on the new tank was such that in order to slide the hose on, the tube needed to be bent up away from the tank. (Bubba might have a job building gas tanks)
There is about a gallon of gas in the tank. I believe I could probably heat the solder enough to make a good seal with out a problem using an iron or even a torch. Logic tells me not. I could use JB weld or a sealer of some kind but I would like to do it right.
1. Torch it and melt the solder
2. Use an Iron and heat it enough to make the seal
3. JB weld
4. some other sort of sealer
5. Empty the tank and fill it with water
6. Duct tape
If the vote is for number 1 and you don't see any more posts from me,
you can send email and my wife might have some misc 60 parts for sale.
What do you think?
3. JB weld
6. Duct tape
What do you think?
