Re: Solder a vent tube on a C1 gas tank?
Michael, check your chemistry books. Carbon monoxide is a flamable/explosive gas. Get the right concentration and it just adds to the problem with gasoline vapor. If you have to solder a tank, steam out to clean. Take an air hose with an open ended coupler. Attach your hose to a pressure regulator to reduce the pressure so as the hose will not whip around when you turn it loose. Insert open end in gas tank and turn on the air. Let it thorourghly ventilate the tank. Leave the air on and start your repairs using a heated soldering iron, nothing that produces a spark or flame. As long as the air is flowing in the tank it should be too lean to do anything. You should be below the lower explosive limit, 1.3%. I have repaired tanks in the past using this method, but personally I would sent it to a shop that specializes in this type repair. Clem's post of using dry ice is also a good tip. Dry ice is CO2 which is an inert gas. This will displace the gas vapors also
