C1-C2 rear quarter panel repair - NCRS Discussion Boards
  • Ron R.
    • August 31, 1993
    • 159
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C1-C2 rear quarter panel repair
    Ever seen those Duct Tape calendars? You have just found another use.
    • Ron R.
      • August 31, 1993
      • 159
      Never seen a duct tape calendar, but I have a feeling I'll be making one of my own.
      Thanks for the tip Wayne.
      • Jim T.
        • March 1, 1993
        • 5351
        In the July 2004 issue of Corvette Fever there is an article on replacing the front left fender using paint sticks and masking tape a a couple of big clamps. Interesting technique. I replaced a front fender about twenty years ago, my first attempt. The local Corvette body repairman that worked at the Chev body shop and also at his own shop guided me information on how to do it. I used big washers on each side of a small bolt using winged nuts to secure the panel and filled in the holes later. My first attempt to install the panel I like you had mixed the adhesive where it was setting up to quick. I quickly removed it and began removing the adhesive. Next time was perfect. I am still amazed today when I look at the repair and it is still a perfect repair, nothing visble after all these years.
        • Dennis A.
          • April 30, 1999
          • 1010
          Jim...
          I used the big washer method about two years ago with success. Came across the method insome book, I'll see if I can refind it...
          • Scott Marzahl
            It's also recommended to contersink that hole you used for the #10 machine screw and washer to help prevent the filler from shrinking and ending up with noticeable sink marks.
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1464
              The holes are not needed and they always return...
              There are videos showing how-to without holes. Briefly, place "puts" along the joints, a spot of bonding adhesive the thickness of the final bond, so you can apply pressure without squeezing all of the bonding agent out of the joint. Tape, clamps and several sets of hands help. The stuff sets up quickly enough that your friends shouldn't get to torqued.
              Good Luck
              H. a. N. D.
