Hi everyone.
I have a question, does anybody restore old copper Radiators & Condensor's? Also does anybody sell restored or NOS Condensor's and Radiators. Let's first start with the Radiator. I really don't know if the Radiator that came out when I torn down the chassis is the original. I don't know what markings or numbers to look for because my Judging Guide says that there is a metal tag attached to the passenger side header tank of the Radiator with the brodcast code letters and the part number for the Radiator. I don't have the tag the Judging Guide is talking about. But I do have a metal tag on the upper right corner on the Driver's Side on the Condensor side of the Radiator. The tag reads as follows :
3R 10375
86 080
MADE IN U.S.A.
I really don't know at this point if it is the orignal, but it is a copper Radiator, But from what I really don't know.
The Condensor I removed from the car has no numbers or codes on it, But it has alot of bent fins. I talked to my local GM Dealer and a new Condensor is available from GM. But the GM dealer told me that it has changed part numbers. The problem I see here is by the Condensor changing part numbers that leads me to believe the design of it has changed. My Condensor that I removed has exposed tubes on both sides from top to bottom that go from one tube then curve down to the next. My Judging Guide makes no mention of part numbers or design. All it tells you is there should be any, if few bent fins and that the color should be semi-gloss black.
3R 10375
86 080
MADE IN U.S.A.
