65-66 frame - NCRS Discussion Boards
65-66 frame
  • jim ethington
    65-66 frame
    Is there any difference between a 65 and a 66 frame if the 2 were side by side? Can't make out the serial number. Thank you
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 65-66 frame
    mounting of the 4 Muncie shifter differs. 65's bolted it to the tranny. 66's bolted it to the crossmember, if my febile mind is working.i don't think the 65 frame will be drilled for the shifter mounting bracket. check the assembly manuals. good luck, mike
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's a couple of items
      In addition to Mike's indicators, even though you can't make out the VIN derivative stamp, the rearward location (of the 2 sites) should at least give an idea of early [over the shock upper mount bracket = early to mid '65] vs. late '65; all '66 [just ahead of the rear body mount].
      Also, brake line (front-to-rear) was on top side of frame rail (check holes) vs. on upper inside edge in '66. As part of this, there is no brake line clip hole at the rear frame kick-up
      • Pete Lovrovich
        Re: 65-66 frame
        Early 66 also had the shifter attach to the transmission, at least through Nov. of 65.
        • Mike M.
          • May 31, 1974
          • 8365
          Re: 65-66 frame
          steve: wan't aware early 66's had tranny mounted shifter.this info isn't in the judging manual. is it in the assembly manual(not close to one at this time). if its not in assembly manual, where can io look at documentation? thanks and good luck with your restoration. mike
          • Michael H.
            • January 29, 2008
            • 7477
            Re: 65-66 frame
            Mike,
            I've considered installing the later style frame bracket on my 66 dut can't bring myself to drill the required holes in the frame.
            • Mike M.
              • May 31, 1974
              • 8365
              Re: 65-66 frame
              thanks pete and mike. mikie
              • Michael H.
                • January 29, 2008
                • 7477
                Re: 65-66 frame
                How's that hot rod comin? I was hoping you'd get it finished and drivew it to Florida next month and give me a ride. Is the heater working?
                • Mike M.
                  • May 31, 1974
                  • 8365
                  Re: 65-66 frame
                  waiting for body to come back from painter. done all i can do to the drivetrain. hope to have it running spring. might just drive it to park city. regards, mike
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    Utah?..my. but aren't you an ambious rascal.. *NM*
