It will not fall off. It will not even loosen up if it is tight enough.
Re: Knock off Fell off what is the correct directi
clean threads of spinner and adaptor with ether or laquer thinner and DO NOT lubricate the threads. buy a 3# maul with leather cups on ends. tighten spinner still snug, leave car down on groung then slam away.and i mmean slam the spinner tips. i lost a spinner on I95 near Jacksonville on out first trip to Cypress Gardesn, believe it was '82. i'd wire brushed then Never-seized the adaptor thread before we left for Cyprus. i believe lubrication and inadequate slamming atribute to loose spinners. since that freightening loss of spinner on I95, i've never lost another spinner on any of our numerous K/O equipped midyears when i've cleaned any lubricants off threads beforehand. good luck with yours. mike- Top
Re: You have another choice,
Mike, I use Never Seize on the threads and the cone and have never had a problem, but I am leary of anything but the lead hammer. I dont think that you get as much on them with other devices. A note: at those torques the cones tend to score. Thats why I like the Never Seize. Also I think that you can get more torque on the nuts with some lube. The fact is that if you have the nut tight, they aint comming off, lubed or not.- Top
I use Locktite 592 (pn59241) that appears to work very well and you can take the wheel off again. I mark the cone and spinner with a small yellow line (china-marker) and check for position each time I'm about to drive away.
Have a real fear about a KO coming off, since many of my friends had that happen to them in the 60's with damage to rear glass resulting. I first used the red Locktite, but then wanted to take the wheels off - Locktite told me "good luck" However I was able to take emblem off spinner and heat threads and did get them off, Oh I had only used enough red locktite to fill a few spots here and there and that was still a lot of heat and banging to get them off.
Locktite 592 was recommended by Locktite and it appears OK.- Top
