When I attempted to install the re-production door locks on my 60 I found that they were not the same as originals. They are from CC and there is NO way they will fit without modification. The space between the tabs and the bezel is not large enough for the backing retainerr to fit. I believe the lock they sold me would work just fine on a steel bodied car. The differance in thickness between sheet metal and the fiberglass is the problem. I ground the tabs away on the locks enough so that I could force the backing retainers in place.
I can't believe everybody that has bought these doesn't have the same problem.
Larry
Larry
