I am soon to tackle one of the things I have been wanting to do for some time, and that is to remove and cleanup my inst cluster. I did some quick checking and it seems that the price to have this done by sending it out is way more than I want to spend. Therefore, I will do this work myself. I am already up to speed on the removal procedure. Once I have it out, my goal is disassembly and cleaning, lubrication of key parts, and stripping/painting the pot metal housing. Can the forum offer any advice as to specific things that I should make sure I do while I have things apart? What specific parts should I order in advance that will need to be replaced for example. I know I need all instrument lights, but what are the other standard things to replace? Seals, gaskets, filters, etc, etc.? Tricks from your experiences?
Also, I may disassemble the steering column while I have it out too. Is disassembly and cleaning of the standard 67 column difficult and/or required since it appears to function fine. I have a small amount of side to side play on the top end of the shaft but not much. Maybe just an adjustment? Is bearing replacement recommended or required for a car this age?
Thanks folks!
Tim
Thanks folks!
Tim
