Terry's correct. External, discrete ballast resistor disappeared in the Shark era across the board on Chevys. Function (maximize spark voltage during engine cranking and reduce during run) was accomplished INSIDE the ignition wiring harness using controlled resistance wiring runs (like was done with earlier TI systems with their special wiring harness).
For grins, EE's simply HAVE to explore/tinker, two of us disassembled coils to see what's what inside. One was a burned up '091 (HP coil from days of discrete ballast) and the other was a passenger car 'B-R' series from '69-70 era.
Inside the '091, there was magnetic continuity in the core lamination circuit coupling primary to secondary (a very conventional transformer design). In the 'B-R' coil, there was a VERY SMALL air gap in the core lamination that was 'stuffed' with plastic. While the magnetic circuit has to 'jump' this gap to couple primary to secondary, due to its VERY short distance there is only minor efficiency loss. Appears the design was intended to control transient decay and fully isolate primary from secondary electrically. Interesting....
