anti-sieze
  • Mark Hedberg (30810)
    • August 1, 1998
    • 384
    #1
    anti-sieze
    what is the best way to remove permatex anti-sieze? I need to remove it from a fitting so I can use thread sealant instead. Thanks.
  • Duke Williams (22045)
    • 15229
    Re: anti-sieze
    If you're referring to Permatex Form-a-Gasket (the brown goo in a tube), it should be soluble in denatured alcohol.
    • Ralph Esposito (37280)
      • February 1, 2002
      • 905
      Re: anti-sieze
      Mark,
      If you really mean anti-sieze spray on stuff, I would try try using lacquer thinner.
      Ralph #37280
        • August 1, 1998
        • 384
        Re: anti-sieze
        Not the spray on stuff, but the stuff in the tube. Comes in two varieties that I've seen - one is a silver color and the other is copper. I've found that the stuff gets everywhere and is very hard to clean. I'll try the lacquer thinner.
