I have put my car away in storage for the winter, as a result i can not check out if the nipple on the intake uses a 5/8 or 3/4 heater hose. I believe it uses the small 5/8 hose. I am going to put a new intake on and the new one has no fitting in the intake. can someone help me out?
LS5 intake heater hose size
Re: LS5 intake heater hose size
Jeff----
The intake manifold heater hose nipple is for 5/8" hose size; the water pump mounted nipple is for 3/4" size. The original GM part number for the maniold nipple was GM #3838094. The current-day GM replacement is GM #345501. The water pump nipple was originally GM #3849848. The current day replacement for it is GM #6272959. I do not know how the replacements differ from the originals in configuration.In Appreciation of John Hinckley- Top
