High lift cam - NCRS Discussion Boards
High lift cam
  • Danny Vrachan
    High lift cam
    What is it that gives the 1980 L82 the extra 40 hp? Is it the 9:1 pistons alone or is there a mild cam inside that helps out. I cant seem to find anything in the manual to show any other differences other than just the compression ratio. thanks in advance, Dan
    Re: High lift cam
    Danny-----
    The main difference in horsepower is provided by the cam. Other differences in the engine support the extra power and RPM.
      • 15610
      Re: High lift cam
      The 3896962 cam was used in the L-46 for '69 and '70, and it reappeared as the "L-82 cam" from '73 to '80.
      Compared to the L-79 cam it has 3 degrees more .050" lifter rise duration and is phased four degrees later. With its longer stroke, the 350 needed a little "more cam" to have the desired SHP characteristics.
