I have a pair of repro aluminum valve covers with fel-pro gaskets on my 61 283 vette. I have a pooling of oil between the oil fill tube and carb. The covers do not appear to be leaking. Where is this oil coming from?
Oil Oil everywhere
Re: Oil Oil everywhere
I too have had this problem, and for years attacked it by putting sealer on the intake manifold bolt threads. I had mixed success with this method. I've had much more success by removing the intake bolt in question, cleaning it, chasing the thread on the bolt with a die from a tap and die set, and re-installing the bolt. I haven't had that fail yet.
Bill Baird- Top
Bill, one other area not mentioned is the bolt holes for a coil. One of the holes [don't remember which one] goes directly into the lifter valley. As you drive oil will come out of that hole. This happened to me with my 57 with dual quads. I don't know if this is true with a cast iron manifold, but take a look. Obviously, I know this is not where your coil or mine is held, but it is on passenger cars.- Top
Bill -
Been there too - I clean the bolts thoroughly, apply ARP Thread Sealer, and torque to 25-30 ft-lbs. Result? Dry city - no leaks. I also use very thin stainless flat washers under the bolt heads to keep from chewing up the aluminum manifold (CC sells the special washers - O.D. is slightly smaller than the bolt head so you can hardly see them).
John - '57 270- Top
